LabWindows/CVI
SqlToolkit Problem with CVI 2009 and Windows7
I'm using the test version of CVI 2009 and have a problem with the sql toolkit which works fine under CVI 8.5.
DBNewConnection()  returns always -100 and the error message is NULL.
Did you have any ideas what causes this problem and how it can be solved?
Thanks in advance
Inomed1
(3,323 Views)
Hello Inomed1
have you tried to reinstall the SQL Toolkit?  I found some cases in the past where this has been helpful.
For further investigation it would be interesing witch DBMS is used?
Regards
Moritz M.
(3,279 Views)
I have the same problem,Is there anybody have the right solution?As same time,I create a new project to test DBNewconnection.It can work. Is the old project referance something that raise the problem?
(2,965 Views)
