Starting CVI IDE project file with parameters to make project build and application run
Hi all,
Is there a way to the following steps in CVI IDE without user explicit actions:
1. Build
2. Run the application.
I mean, open a CVI project (*.prj file) from a shortcut, and trigger BUILD and then RUN commands. Or, immediately RUN, because it also builds the project.
Thanks for the support
(3,482 Views)
In this page you can find available startup options for CVI: it appears that -run_then_exit is probably the best solution for your needs.
(3,469 Views)
Thanks - I will definitely look into it and try 🙂 it really looks like the right thing for me
(3,451 Views)
Hi again,
I'm creating a shortcut to a *.prj file, and edit the "target" with path to my *.prj in shortcut properties.
The target looks like that "path\to\target\project.prj -run" that doesn't seem to work for me, it just opens CVI project but doesn't build/run it. What do I miss here?
(3,433 Views)
Accepted by ArtB83
You have to create a shortcut to CVI itself, not to a project. The command line options are specific to CVI program and are not executed when it is launched automatically by a link to a project.
The CVI shortcut can then be edited adding the project name ant whichever supplementary option you want.
(3,431 Views)
Yap, now it works 🙂 thanks
(3,418 Views)
