03-26-2018 07:38 AM
Hi all,
Is there a way to the following steps in CVI IDE without user explicit actions:
1. Build
2. Run the application.
I mean, open a CVI project (*.prj file) from a shortcut, and trigger BUILD and then RUN commands. Or, immediately RUN, because it also builds the project.
Thanks for the support
Solved! Go to Solution.
03-26-2018 08:55 AM
In this page you can find available startup options for CVI: it appears that -run_then_exit is probably the best solution for your needs.
03-27-2018 12:33 AM
Thanks - I will definitely look into it and try 🙂 it really looks like the right thing for me
03-28-2018 04:53 AM
Hi again,
I'm creating a shortcut to a *.prj file, and edit the "target" with path to my *.prj in shortcut properties.
The target looks like that "path\to\target\project.prj -run" that doesn't seem to work for me, it just opens CVI project but doesn't build/run it. What do I miss here?
03-28-2018 05:04 AM - edited 03-28-2018 05:05 AM
You have to create a shortcut to CVI itself, not to a project. The command line options are specific to CVI program and are not executed when it is launched automatically by a link to a project.
The CVI shortcut can then be edited adding the project name ant whichever supplementary option you want.
03-28-2018 06:33 AM
Yap, now it works 🙂 thanks
