String modifiers
I need to send a 16 byte command to the com1 buffer using comWrt (ie: "AA1000FFFFFFFFFFFFFFFFFFFFFFFFFF").
What string modifiers would I use so it doesnt convert the string to ASCII values and therefore needing 32 bytes.
(3,160 Views)
The string modfiers to format 8-bit values into a string is %c. It accepts values in the range 0÷255.
(3,160 Views)
