Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
String modifiers
String modifiers
Cesar T.
Member
06-11-2004
02:26 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to send a 16 byte command to the com1 buffer using comWrt (ie: "AA1000FFFFFFFFFFFFFFFFFFFFFFFFFF").
What string modifiers would I use so it doesnt convert the string to ASCII values and therefore needing 32 bytes.
0
Kudos
Message
1
of 2
(3,159 Views)
Reply
Re: String modifiers
RobertoBozzolo
Proven Zealot
06-12-2004
03:14 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The string modfiers to format 8-bit values into a string is %c. It accepts values in the range 0÷255.
0
Kudos
Message
2
of 2
(3,159 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
