LabWindows/CVI
Stripchart sweep/block mode not working in 2010
These two modes on the strip chart control stopped working in my software with the 2010 upgrade.  Continuous mode still works.  I even loaded the NI example 'autoscaling.cws' that uses a strip chart control and modified it to default to sweep mode instead of continuous...it doesn't work either.
Any ideas?
(3,031 Views)
Accepted by topic author AMM
Hello -
This is actually a known issue in CVI 2010 (ID 258827).  I will be making a more official announcement regarding this issue on this forum soon.  In the meantime, you can download and install the CVI 2010 Run-Time engine found here, which contains the fix.
Let me know if you have any questions -
NickB
(3,024 Views)
Thanks!  Works great now.
(3,017 Views)
