LabWindows/CVI
TCP/IP Multiclient Handle Error
I am writing a multiclient-server program based on TCP/IP in CVI v. 8. And I took the server.prj as example
I have an connection issue, because the server does not get the client handle. My clients are not  PC’s, they are wifi Embedded Devices and I can not create an identifier as is done with a PC, I just get the IP.
The error is generated into ServerTCPCB function that gets the handle (I attached image):
int CVICALLBACK ServerTCPCB (unsigned handle, int event, int error, void *callbackData)
When I have a client  I can get the information correctly, but when I add another client I can not know who is sending the information. Is there a function that just uses the IP to send and to receive info or what could you suggest me to solve this issue?
Mauricio
(3,424 Views)
Hi mhhernand,
Have you looked at the CVI shipping example that shows you how to handle multiple client connections?  You can find it at c:\....\CVI\samples\tcp\MultiClientServer.prj.  Hopefully, this example will be of some use in solving your problem.
Erin
NI Mexico
(3,391 Views)
