LabWindows/CVI
related to C string and file handling
Hi ,
In an application programme I am using two C files(say  F1.c and F2.c ). In F1.c I have declared a structure named
struct A
int i;
}Object;
Now when I am using this structure in other file F2.c the structure object and struct variable , compiler says undefined variable etc .
now tell me how to declare the variables ( i.e Object & i) in F2.c and use these in F2.c ?
subrata
(3,886 Views)
You need to use a header file, containing the structure definition and #included by both of your c files. I would use a system similar to this:
<this is a new header file, eg defs.h>
typedef struct A {        // I prefer to use typedefs, especially in a header file
    int i;
} structA;
extern structA Object;    // This tells the compiler that another source
                          //  file is responsible for defining the variable
<within your F1.c and F2.c files, include this line:>
#include "defs.h"
<within just one of your source files (it does not really matter which), you need to define the actual variable at the top level>
structA Object;
In this manner, both your c files are aware of the single Object at compile time.
JR
Message Edited by jr_2005 on 03-08-2007 10:41 AM
(3,880 Views)
I see object name does not generate any error during compilation but the structure variable i.e int  i  ; causes the error .
subrata
(3,876 Views)
Could you post a copy of the line which the compiler complains about?
JR
(3,872 Views)
Hello JR ,
Your suggestion is working now .Thanks a lot
subrata
(3,845 Views)
