LabWindows/CVI
TDMS log last N hours
Hi, i'm working on project. We are doing acquisition during very long time (can be 60 days). I need to log on harddrive the last 2 hours .
In normal condition i need to save 5 minutes every 2 hours . In case of failure i need to save the last 2 hours. (Frequency of acquisition is low 20HZ)
Is it possible to use tdms recording to achieve this . At first i'm thinking to limit sample by file, then extract data from tdms to create new one.
Regards
(3,045 Views)
Hello, it seems to me that what you need is some sort of circular buffer 72000 elements long (3600 sec * 2 * 20Hz). TDMS is not the proper instrument to achieve this, since you cannot delete elements from the file once written; I suggest you to keep all data in memory instead, and dump the whole set of data to disk only in case of failure, with a format at your choice.
A good and simple way of storing data in memory for this purpose is to have an 72000-elements array with proper initialization at program start; when you need to record a measure, you can shift all elements by one to the right and store actual measure in element 0: that way your data will be always stored in the array sorted from the most recent backwards with increasing index.
(3,035 Views)
