LabWindows/CVI
How to prevent a union field selecting window at the debug time?
Using the GetDiskFreeSpaceEx() API to get the disk free space volume at the debug time, it always popup such a window:
I'd like to know how the prevent the enquiry?
David
(3,105 Views)
I suppose you receive this popup when you try to examine the variable in the variables window with Shift+F7, right?
If so, if you select the specific part of the union you want to see, you won't receive the popup. That is, supposing you have a variable
ULARGE_INTEGER    ds;
if you highlight for example ds.QuadPart you won't see the popup.
(3,100 Views)
