LabWindows/CVI
TOOLBAR_ATTR_SHADING_BITMAP?
Could anyone please elaborate on the documentation about the toolbar attribute "TOOLBAR_ATTR_SHADING_BITMAP"? The documentation only says:
Data Type:integer
Description:Allows the user to specify a 1-pixel wide bitmap of arbitrary height to draw as the toolbar background. You can use an alpha blended pixmap to produce an effect that adapts to various user color schemes.
Any examples on how to use this attribute?
mpenav
(2,915 Views)
Update:
I got it working now...the issue was, setting this attribute seems to have no effect on the toolbar if the toolbar style is set to TOOLBAR_VAL_RAISED.
mpenav
(2,914 Views)
