LabWindows/CVI
Tab Control
Does anyone know if the TAB control can notify me when a user selects a
tab? ie, I would like to be informed when a user changes a page in the
tab control.
Mitch
(4,315 Views)
I just figured it out in an example provided by NI.
Thanks.....
> tab control.
> Thanks,
> Mitch
(4,312 Views)
would you tell me how can i get the NI examples for the tab control
(4,091 Views)
They're located in \samples\userint\custctrl\easytab folder.
Or you can use the example finder (Help >> Find examples... menu function) and search for "tab".
(4,082 Views)
This depends on which version of CVI you're using.
If you're using version 8.0 or later, NI recommends that you use the built-in tab control in the UI library, and not the easytab custom control. You can find examples for the built-in tab in samples\userint\tabpanels.prj and samples\userint\tabexample.prj.
If you're using a version of CVI older than 8.0, then you can only use the easytab control, and you can look for the examples that Roberto indicated.
Luis
(4,066 Views)
