Tab Order
Is there anyway in LabWindows to disable a controls tab order.
I have some Edit String Controls on my UIR that I do not want to be part of the cycle when I tab through
the controls.
(3,655 Views)
You can skip controls by using SetCtrlAttribute to dim them, or set them to be an indicator. You can also programmatically control the tab order. See the additional discussion and my TabOrder example at the bottom of the discussion here [broken link removed].
(3,655 Views)
The taborder example is exactly what I was looking for.
(3,655 Views)
