LabWindows/CVI
Tab with Scroll Bar
I was wondering is there a way to add a horizontal scroll bar to a tab control !?
Kobi Kalif
Software Engineer
(5,527 Views)
Accepted by Kobi_K
You can: use SetPanelAttribute ( tabpanel_1_handle, ATTR_SCROLL_BARS, VAL_HORIZ_SCROLL_BAR);
But you shouldn't (see the design considerations here😞
  • Don’t Use Scrolling Inside Panes - Scrollbars are an added encumbrance to users interacting  with module tabs: to access the information that they are looking for, not only  do they have to click on tab controls, but they also need to use scrollbars to  see if the content they want is farther down the pane. The need for scrollbars inside panes outlines an issue with  regards to the length of the pane information or the design of the module tabs; either the content being presented is too long for the module tabs design  pattern, or that the pane area is not tall enough for your content. Consider  revising content for terseness, extending the height of the pane area, and/or  allowing for variable height of the pane area depending on the pane information  length of the active pane.
(5,524 Views)
Thank you !
Kobi Kalif
Software Engineer
(5,517 Views)
