LabWindows/CVI
Table Auto Scroll
I have a table with 20 rows and 5 columns.
The table is updated every second with new rows/data which go past the 20 rows.
However, the table is not auto scrolling to keep up with the new rows.
Is there a way to auto scroll or have the table keep up with the latest row ?
Diego
Message 1 of 8
(6,710 Views)
Hi Diego,
after you insert the new table row, just add this code:
     GetNumTableRows (panel, PNL_TABLE, &num_rows);
     SetCtrlAttribute (panel, PNL_TABLE, ATTR_FIRST_VISIBLE_ROW, num_rows);
Message 2 of 8
(6,694 Views)
Wim,
Thanks very much for your suggestion.
Would you happen to know how to add a complete BLANK row ?  I have both string and bouble columns and not sure how to add a complete blank row.
Diego
Message 3 of 8
(6,685 Views)
Hello Diego,
A table cell containing a numeric value cannot be empty, so it is not possible to add a complete blank row when the table contains double columns. A possible work around would be to represent the double values in a string cell.
Message 4 of 8
(6,682 Views)
Wim,
Yes, I came to the same conclusion, but was double checking.
Thanks again for your input.
Diego
Message 5 of 8
(6,678 Views)
Hello Diego,
If it's cumbersome for you to change the cell types, another solution might be to change the text color: get the value of the ATTR_TEXT_BGCOLOR cell attribute, and then set the ATTR_TEXT_COLOR cell attribute to match that color.
Luis
Message 6 of 8
(6,660 Views)
Hi Luis,
When the cell becomes active, the background will turn blue, and the text will become visible anyway Smiley Sad
Message 7 of 8
(6,640 Views)
Ah. Excellent point. I hadn't thought of that.
Message 8 of 8
(6,627 Views)
