LabWindows/CVI
Table control in CVI 7.0
I am using the classic style table control as an indicator in CVI7.0. I see that one of my cells is always highlighted. I observed that depending on when I change my table from a hot control to indicator, I see either 1 cell or bunch of cells highlighted.
I don't want any cells to be highlighted. Is there something that I can do.
vishi
(2,980 Views)
Yeah, there is something you can do. Before setting the table to be an indicator, change its run state to edit mode:
SetCtrlAttribute (panel, PANEL_TABLE, ATTR_TABLE_RUN_STATE, VAL_EDIT_STATE);
That should do the trick.
Luis Gomes
NI
(2,980 Views)
