LabWindows/CVI
Tektronics TDS224 with commuication is GPIB
Can someone help me to find example for Tektronics TDS224 Oscillosope? i need to read  data from all the channals sametime, mode of communication required is GPIB.
if anyone uses same code pls post the same or post the link.
Joe
Using Ver. 8.0
(3,518 Views)
I searched the Instrument Driver Network on our website and found a LabWindows/CVI TDS 210 driver.  Hopefully you can make this work for you.
Robert Mortensen
Software Engineer
(3,491 Views)
Thanks for the help.
this .msi file i downloaded but this requires IVI to be installed. so i downloaded  IVI Compliance Package  (ICP25) and installed. i got some error while installing ICP25. now if i use any function in IVI class drivers which is in the function pallete, it ask for ivi.dll
pls help me.
Joe
Using Ver. 8.0
(3,482 Views)
See KnowledgeBase 3SJAMOEG: IVI Shared Components Installation Error 1935.  Hopefully this will resolve the installation error.
Robert Mortensen
Software Engineer
(3,471 Views)
