Text file size
How to get the text file size from the directory.
(3,931 Views)
I can understand text size and file size, but I do not understand text file size - the size of text files?
The size of files wether text or binary can be obtained using GetFileSize, but this you know according to your other post.
Why don't you spend two seconds more to express your questions more clearly?
(3,924 Views)
its file size, 'm writing the file in C: directory and need to check the size of the file if its more than 512 MB need to create a new file.
(3,903 Views)
Accepted by rr_04
OK, so why not use GetFileSize as discussed in your other post?
(3,891 Views)
yep I have used it to get the file size. Now if I want to delete first few entries in file ?
(3,884 Views)
OK, so this thread is solved Smiley Happy
Second, you can't - I have answered this question here
Third, if people have helped you can acknowledge their help by giving kudos. Smiley Wink
(3,877 Views)
