LabWindows/CVI
The ActiveX controler gives me a hard time.
Hi.
I alredy put this question on the forum but a didn't get the answer so I will try to be more explicit.
I want to use 2 ActiveX controls: first when I create the calendar control and the second when I create an Excel control.
It doesn't mahters what control I create first, the second one fails to be created due to an error that apairs at the opening:
"ActiveX control error"
So I tried to use, before creating the second controler, this functions:
status = DiscardCtrl (My_handle, calendar);
CA_DiscardObjHandle (*objHandle);
because I was thinking that I must eliminate from memory the first ActiveX control, before I create the second one.
This solution doesn't work.
I put an example of what I try to
do. Press the Open Excel button before presing the Open Calendar button and you will see the error.
Thanks.
(3,055 Views)
This is one of those situation where I know how to fix this but I don;t have the theory to support it. To be able to launch Excel and then the calendar control you need to change the ActiveX threading model.
For what I know, lauching Excel was initializing the ActiveX interface in COINIT_MULTITHREADED mode. Thus not allowing you to use ActiveX controls in that same thread. using the function call CA_InitActiveXThreadStyleForCurrentThread(0,COINIT_APARTMENTTHREADED) at the top of your code, you force CVI to use the COINIT_APARTMENTTHREADED threading mode that allows you to use ActiveX controls. You can find more details on this is the help for the function CA_InitActiveXThreadStyleForCurrentThread; make sure that you call this function before calling a
ny ActiveX functions.
Let me know if you have any further questions.
Juan Carlos
N.I.
(3,055 Views)
