LabWindows/CVI
The Difference between install a control callback and setting it directly.
In cvi GUI programming , I can set a control callback function in the edit dialog , and also I can realize this by using "InstallCtrlCallback()" , I'd like to know if the 2 ways would have different performance ? Thanks.
David
(3,237 Views)
No, performance should be exactly the same in the callback execution and response time to events.
Best Regards,
Chris Matthews
(3,237 Views)
This just means the execution performance is the same, when using "InstallCtrlCallback()" , the program have to experience a sequence of callback install procedure , I am afraid that this procedure would bring up a bad affection to the application loading process .
David
(3,237 Views)
