LabWindows/CVI
sample rate?
I run the sample program "ai_samp.prj" in the path "easyio".
I set the smaple rate to 1000Hz,but the acutal smaple rate shows 400Hz.I
want to know why.
(3,790 Views)
Shen,
This question is answered HERE.
Good luck with your application.
Spencer S.
(3,790 Views)
Spencer S,
Thank you.
I want to sample data and show it on the screen at the same time
continuously .How can i do? Are there any examples? I'm a beginner.
Shen
(3,790 Views)
Shen,
Absolutely. If you want to continue using the Easy I/O functions, the ai_async.prj example both continuously acquires and graphs.
Spencer S.
(3,790 Views)
Thank you.But ai_async.prj is an asynchronous one.
If I need a synchronous one to achieve high sample rate, do I need extra
hardware in windows2000?
(3,790 Views)
Synchronous Vs. Asynchronous is a "concern" when dealing with finite operations, not continuous as you have indicated you want to perform. With regards to speed, I would suggest that you create your application based on the DAQdoubleBuf.PRJ example available in the following location:
C:\Program Files\National Instruments\MeasurementStudio\CVI\samples\daq\Ai
This example does not have a user interface, but I have attached an example I created sometime back that acquires continuously from multiple channels and displays the data on a user interface.
Good luck.
Spencer S.
(3,790 Views)
