04-24-2008 04:46 AM
04-24-2008 06:49 AM
04-28-2008 09:46 AM
04-28-2008 10:09 AM
Hi Diana,
No I didn't try to repair my CVI installation (I installed it two week before), but I can do it once I'll finish my work, not before...
Fortunally I've got a copy of this fp file, then this is not really a problem for me right now.
I've put the .fp and .h file in attachment, hopes this will help you. (you must specify AGN6030A instead aaAGN6030A in the Confirm Driver Prefix dialog...)
Note:
* the following dialog appears if I try to revert to format 5.5 and late: 'This file currently contains controls that use 64-bit integer data type, which are not allowed in the new file format you have selected'.
Of course, this is due because int64 was introduced in CVI 8.5... and I suppose that the std.exe maybe wasn't updated to support this type....
Levent
04-29-2008 01:42 AM
04-29-2008 01:57 AM
No but originaly the same driver. I've got it internaly because I'm in charge to update it...
But what does it matter?
The problem is that if you change the format of a fp file from 5.5 to 8.5, the Test IVI Specific Driver Tool simply crash.
And as I mentionned in the last thread, using the tool with the fp file in the 5.5 format works very well (fortunately I've got a copy of the file before converting it to 8.5...)
Then I decided to keep the format to 5.5 and later...
04-29-2008 02:21 AM
04-29-2008 11:27 AM
Hello leventagile,
I'd like to be able to reproduce the problem with this driver that you submitted, but in order to do so, I need to either have the corresponding dll, or the source code for the driver, so that I can build a dll with it. Would it be possible for you to attach one of those as well?
Thank you much!
Luis
04-29-2008 11:27 AM - edited 04-29-2008 11:27 AM
<duplicate post, please ignore>
