LabWindows/CVI
Thread-safe DAQ session variable changes during of after a call to NI435X_Check_And_Read()
I'm using a Pentium 4 with an NI4351 PCI DAC, freshly installed Win XP Pro OS, LabWindows/CVI 7, and an updated NI435x driver. From inspection of debug output, the NI435X_Check_And_Read() function appears to change the DAQ session variable, even though it never returns an error. The typical debug window output and subsequent code segment that generates it, follows:
Debug window o/p: // (with my comments)
 Session is 21776664 before read (on 04-10-2006 @ 09:43:13)  // (displayed because the static 'DAQ_Session' var is initially 0)
 Session is 21776664 after read (on 04-10-2006 @ 09:43:13)   // ditto
 Session is 1057789952 after read (on 04-18-2006 @ 02:01:35) // invalid session value after 8 days continuous operation!
Code snippet called from asynchronous timer:
static TSV_DAQ_Session *DAQ_SessionPtr = 0, DAQsession = 0;  // (global typedef variables)
 if (event == EVENT_TIMER_TICK)
     ViReal64 *DAQ_Data = GetPointerToDAQ_Data();
     static int DAQ_err = NI435X_SUCCESS;
     DAQ_SessionPtr = GetPointerToGlobal_TSV_DAQ_Session();
     if (DAQsession != *DAQ_SessionPtr)    DebugPrintf("Session is %d before read (on %s @ %s)\n", *DAQ_SessionPtr, DateStr(), TimeStr());
     DAQ_err = NI435X_Check_And_Read (*DAQ_SessionPtr, -1, &scans, DAQ_Data); // (no error returned here)
     if (DAQ_err != 0)    DebugPrintf("Error code %d on %s @ %s\n ", DAQ_err, DateStr(), TimeStr()); // (never an error here)
     if (DAQsession != *DAQ_SessionPtr)    DebugPrintf("Session is %d after read (on %s @ %s)\n", *DAQ_SessionPtr, DateStr(), TimeStr());
     DAQsession = *DAQ_SessionPtr;
     ReleasePointerToGlobal_TSV_DAQ_Session();
     // other code
All energy-saving and sleep facilities are disabled on PC. After occurance of invalid thread-safe session number, I get the following error:
NON-FATAL RUN-TIME ERROR:   "file1.c", line 109, col 1, thread id 0x0000044C:   Library function error (return value == -14901 [0xffffc5cb]). Invalid handle.
The code at this line is:    DefineThreadSafeVar (TSV_DAQ_Session, Global_TSV_DAQ_Session);
A fatal-run-time error occurs after this because a subsequent call to GetPointerToGlobal_TSV_DAQ_Session() of course returns a null pointer. The crash occurs more frequently if I remove the DAQ-session checks. Any ideas on what's happening and how it might be remedied would be appreciated.
Many thanks,
John.
Message 1 of 1
(3,107 Views)
