Timed popup windows?
Anyone got a message box popup with countdown timer so if nobody seems to be watching, the program clears it out and resumes as normal?
(4,122 Views)
Accepted by KevinMac
It's a few lines of code only:
InstallPopup
start timer (set control enabled) with a timer callback
in the timer callback:
stop timer
RemovePopup
(4,114 Views)
Hi, instead of RemovePopup , it is better call HidePanel.
Because RemovePopup remove most active Popup panel, and if there is more than one popup panel in application that can be active in the same time ... the problem appear 🙂
(4,078 Views)
