LabWindows/CVI
Timed popup windows?
Anyone got a message box popup with countdown timer so if nobody seems to be watching, the program clears it out and resumes as normal?
(4,120 Views)
Accepted by topic author KevinMac
It's a few lines of code only:
InstallPopup
start timer (set control enabled) with a timer callback
in the timer callback:
stop timer
RemovePopup
(4,112 Views)
Hi, instead of RemovePopup , it is better call HidePanel.
Because RemovePopup remove most active Popup panel, and if there is more than one popup panel in application that can be active in the same time ... the problem appear 🙂
(4,076 Views)
