LabWindows/CVI
Timer intervall problems (runs to fast)
i use the timer functions very often and normally everything works fine. In
an actual programm i setup a timer to an intervall of 5 Seconds. It works
fine on all pentium pc's but it runs much to fast on a PC with an AMD-Athlon
64 X2 Prozessor. I tryed other cvi-programms with timer functions and i
found the same problem. Is this a known bug with this amd processor?
Norbert Rieper
PS: I use CVI 8.0 and windows XP SP 2.
(3,726 Views)
The problem also appears with the NI-Example "timer.prj" in:
c:\Programme\National Instruments\CVI80\samples\userint\timer.cws
"Norbert Rieper"
"Norbert Rieper" <nrieper@isitec.de> schrieb im Newsbeitrag news:43ec86b4$1@PYROS.natinst.com...
> Hello,
> Norbert Rieper
(3,716 Views)
I know underneath we use the QueryPerformanceCounter() for timer functions. I'm just guessing, but perhaps this Microsoft KB might solve the problem.
Message Edited by bilalD on 02-10-2006 05:05 PM
Bilal Durrani
NI
(3,711 Views)
Thanks a lot,
i modified the boot.ini by adding /usepmtimer as discribed and that solve
the problem. Timer intervall is working fine now.
"bilalD" <x@no.email> schrieb im Newsbeitrag
news:1139613209175-323625@exchange.ni.com...
>I'm just guessing, but perhaps <a
>href="http://support.microsoft.com/?scid=kb;en-us;895980"
>target="_blank">this </a>Microsoft KB might solve the problem. Message
(3,689 Views)
