LabWindows/CVI
exporting parameter information to DLL
Hai,
I am trying to export parameter info to DLL,which is upposed to be used with Test Stand.
I have the DLL created already and I just want to add export one function parameter to DLL. SO I just created one function panel and then generated the source for function node. At the end just added .fp,.c,.h files to project and tried to create DLL.
But I am getting message that " Can't create type Library info: The function xxxxx() is in function panel file but not marked for export". Even though I changed Export What: in target settings, I couldn't create the DLL.
Any help plz..
(3,283 Views)
  could you post your project, and let me know which version of LabWindows/CVI you're running please?
The .fp file is used for type library information only, and not for exporting the function.
How have you marked the function for export? (DLLEXPORT or are you using the include header file method?)
Here's information on including the .fp file for use with TestStand
Sacha Emery
National Instruments  (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,265 Views)
