LabWindows/CVI
Transparent Main Panel?
Does anyone know if this is possible?  I'd ike to make an application that is transparent and runs on top of a 3rd party application.  I would plot data in my application over top of the other app.
Do-able or not?  I've looked around and don't see a way of doing it.
Dave
(6,091 Views)
Hello Dave!
Unfortunately there isn't a direct way of making a LabWindows/CVI panel trasparent, by using a predefined panel attribute.
However, here is a workaround to make your panel transparent, using Win32 API:
  1. #include <windows.h> in your source code.
  2. Get the window handle (HWND) of the panel, using the ATTR_SYSTEM_WINDOW_HANDLE panel attribute:
    HWND hwnd;
    GetPanelAttribute (panelHandle, ATTR_SYSTEM_WINDOW_HANDLE, &hwnd);
  3. Configure windows layering:
    SetWindowLong ((HWND)hwnd, GWL_EXSTYLE, GetWindowLong((HWND)hwnd, GWL_EXSTYLE) | WS_EX_LAYERED);
  4. Enable window transparency (see MSDN😞
    // Set the alpha for transparency: 0 is transparent and 255 is opaque.
    double transparency = 50; // Set transparency to 50%.
    double alpha = transparency * (255.0 / 100);
    SetLayeredWindowAttributes ((HWND)hwnd, 0, alpha, LWA_ALPHA);
Hope this helps!
- Johannes
(6,014 Views)
Hi Johannes,
That was exactly what I was looking for.  THANKS!
Just had to change HWND hwnd; to int HWND; in order to get the right variable type for GetPanelAttribute(), which works OK since it's cast to HWND below that.
Thanks again!
Dave
(5,981 Views)
