UI localization issue
I've just notice a strange thing related to UI localization (CVI 2012 SP1).
  • with a text string control, if I change the character set to GB2312 and I paste a string, I properly see it with Chinese fonts
  • if I do the same with a ring (adding a new item), I don't see Chinese fonts (see attached)
is this an expected behavior? or a bug?
Vix
Using LV from 7
Using LW/CVI from 6.0
(5,066 Views)
Hi Vix,
unfortunally don't support unicode in this type of control. There is a Corrective Action Request for your LabView versione: CAR 366041. You can verify if in new version of LabView (next year) this CAR will be fixed!
Mario
(5,032 Views)
Hi Mario,
in your reply you wrote "LabVIEW" but my problem is with CVI Smiley Wink
Where I can verify the status of the CAR 366041?
I don't find it in CVI 2012 Known issues
Vix
Using LV from 7
(5,023 Views)
Accepted by vix
Hi Vix,
There is a known bug that can cause the paste to not work correctly. The bug id is 382556, but I don't think it has been added to the known issues list yet. The bug was introduced in version 2009 and is fixed in the version that is about to release.
The workaround is for you to not only change the character set of the Text Style font but to also change the character set of the Label font to Chinese:
Even though you don't really need to enter Chinese text into the control label, because of this bug you need to set its character set to Chinese if you want to paste Chinese text in the Edit Label/Value Pairs dialog.
Luis
(4,995 Views)
