Use Visual Studio Code as editor for LabWindows/CVI projects
Does someone know if it's possible to use Microsoft Visual Studio Code (this is not the "old well-known" Visual Studio) as an editor for LabWindows/CVI projects?
Every CVI developer knows the the editor itself is really poor (compared to what is available).
I think NI could/should consider the idea to develop a plugin for this editor (someone in the past proposed to switch to Eclipse).
In this way NI can concentrate its efforts in developing analysis libraries and integrating "common" third parties libraries (web, JSON, OPC-UA, ...) relying over:
  • a standard compiler (LLVM/CLANG)
  • a standard and actively developed editor
Vix
Using LV from 7
Using LW/CVI from 6.0
Message 1 of 12
(7,306 Views)
I would be very interested in making our own extension for VSCode for CVI. For compilation, it would need to utilize the command line.
How hard can it be? 😉
Message 2 of 12
(3,009 Views)
Stay tuned everyone... 🤗
Message 3 of 12
(2,773 Views)
I can't wait for news on this topic...
Vix
Using LV from 7
Message 4 of 12
(2,755 Views)
I’m reviving this year-old post to make sure you know about this: LabWindows/CVI Project Manager
I’ve been using it for a few days now as a complete replacement for the LabWindows IDE, and - aside from a couple of things I miss and a few minor bugs - there is simply no comparison
I haven't yet found a way to contact the author to provide feedback.
Carlo A.
Megaris srl
Italy
Message 5 of 12
(1,011 Views)
Thanks.
I'm not able to find any reference of the author nowhere.
Vix
Using LV from 7
Message 6 of 12
(998 Views)
Hello, I did some serious stalking ðŸ˜€ and I've finally found his github
https://github.com/monkeyAtheist/VScode_Ext_CVI
Carlo A.
Megaris srl
Italy
Message 7 of 12
(995 Views)
I simply generated Rust bindings from the CVI headers using bindgen, and now I’m using Rust as the main programming language. CVI’s documentation covers building a project with an external compiler, but nothing says that the compiler has to be C ultimately — the Rust works just as well. All calls from Rust into CVI functions are unsafe, of course, because they go through FFI, the parameters the same. AI can generate Rust code as long as you tell it that you already have CVI bindings available. I’m using GitHub Copilot for this, and it works well. To edit the *.uir panel files obviously I still use CVI, which I keep open side‑by‑side with JetBrains RustRover, my IDE. Bindgen runs on every build to ensure the control IDs are always up to date. The callbacks are handled through the .obj file using CVI’s external‑compiler support, and everything is linked together with the CVI libraries — and it works.
Message 8 of 12
(937 Views)
I don't know anything about Rust, so I can't judge how efficient it is to call C functions via bindings.
In any case, I suspect you'll run into hidden compatibility issues sooner or later. Of course, I hope that doesn't happen, but in my experience, such combinations are rarely trouble-free.
It certainly isn't the right choice for someone maintaining very large, existing projects—like mine—where the standard IDE is no longer viable because it's too limited, throws "out of memory" errors, disables code browsing, and crashes after a while, among other issues.
The VS Code solution, at least for me, is really just about using an IDE that is far more advanced when it comes to text editing.
Regardless, I'm glad there are people out there fighting the good fight and finding alternative paths 😀
Carlo A.
Megaris srl
Italy
Message 9 of 12
(901 Views)
Wow!  Jerry is way ahead of me on this.  Pretty cool so far.
Though it would appear that one can't have more than one instance of CVI open while using this (since debug, build, compile) seem to require the last instance of CVI to connect to.
Message 10 of 12
(868 Views)
