LabWindows/CVI
User Interface Updates Missing
I am using CVI 2013.  I have seen the following behavior on a couple of different projects.  If I make changes to the user interface and build the project, the UI changes don't show up.  If I rebuild (i.e., select rebuild from the build menu) the project, however, the user interface is updated correctly.  This is a nuisance I can work around, but it doesn't seem to be the correct behavior.
(5,317 Views)
Which exact version are you using? Also, are you using embedded UIRs? Similar behaviour has already been reported a couple of times (e.g. here) and should have been corrected in Service Pack 1: see Bug Fix Information document for that version here, ID #433769.
(5,300 Views)
Thanks for the info.  Yes, I have the "Embed .UIRs" button checked.  I am running version 13.0.0 (647).  I'm assuming that the patch to fix this problem hasn't been installed yet.
(5,262 Views)
Hi, Double_D,
You're right. 13.0.0.647 is 2013 f1. The bug has been fixed in 2013 SP1 (13.0.1....)
Daniel Dorroh
(5,253 Views)
