LabWindows/CVI
Using a menu ring to select DAQ device channel and indicator
New user here. I am using the DAQ assistant with multiple analog inputs. I would like the front panel to have a menu ring where the user can select which channels are to be active. Also, this corresponds to a single graphical indicator.
Currently I have a VI that displays all channels each with its own indicator. I want to simplify the front panel so that a user can simply use a menu ring to select and focus on what he/she is interested in. Is it possible to use the Select Signals Express VI to implement this?
Thank you!
(2,946 Views)
Hello, you have ended up posting to the LabWindows/CVI forum: this question pertains to LabVIEW and should be better posted to the appropriate board.
(2,939 Views)
