LabWindows/CVI
dp_base.dll R6030 crt not initialised
Hi
I recently bought a CP5623 Profibus PCI card.
This came with a library for me to create my own application.
The problem im having is that i get a MS Visual C++ Runtime error R6030 CRT not initialised runtime error.
Why is this happening and how do i solve this problem?
Its the first time i see a problem like this and im not sure what to do.
I googled the problem but every situation has a different solution.
I tried reinstalling the the Microsoft Visual C++ 2005,2008,2010 Redistributable Package's but i still get the same problem.
The MSDN explaination does not much either.
Im so lost please help.
Help share your knowlegde
(4,122 Views)
Was anyone able to solve a problem like this?
(4,115 Views)
Hello Shako,
    To get better visibility from PROFIBUS users I believe this would be best posted on the following forum.
    http://forums.ni.com/t5/Industrial-Communications/bd-p/260
Daniel de Gaston
(4,104 Views)
I think i found out where the problem is.
I log onto my pc via a domain and this seems to be causing the problem dont know why.
If i log on to the local PC account then i dont get the error.
Does anyone know what the cause my be or how to fix somthing like this?
(4,083 Views)
