Using same control call back from different tabs
I'm fairly new at this so bare with me for a sec...
I have a situation were I'm using multiple Tabs with the exact same control buttons in each of them.  Since the buttons have the same function I would like to use the same callback.  I understand that each TAB is considered a panel and has its own panel handle.
My problem is that I want the call back to differentiate between the OK button in TAB1 and the one in TAB2.  The panel handle passed down to the call back is (from what I can tell) the panel handle for the tab which is great but it does not have a constant assign to it in the header file.  How do I insure that TAB1 always has the panel handle 2 and TAB2 always has the panel handle 3, etc...
Example:  When I click on OK in TAB1 the panel handle sent to the btnOK callback is = 2.  If I click OK in TAB2 the panel handle is = 3.  I want to switch between the to OK buttons but do not want to use hard coded integer.
int CVICALLBACK btnOK (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
switch (panel){
  case 2:                  <----I don't want a number here but a constant
"do this"
case 3:
"do this"
return 0;
The easy way would be to have a callback for each of the buttons.  If that's the only way to go that that's what I'll do but I'm interested in what you think.
Thanks!
(3,510 Views)
Accepted by nlebouthillier
I can think of at least three ways to obtain what you want.
Solution A: rely on tab page constant name (since you can retrieve it given the panel handle)
Inside the callback insert this code:
char   name[64];
GetPanelAttribute (panel, ATTR_CONSTANT_NAME, name);
if (!strcmp (name, PAGE1)) {
    // Code for first tab page
else if (!strcmp (name, PAGE2)) {
    // Code for second tab page
.... code for additional pages
Solution B: rely on tab attributes
int   parent, index;
GetPanelAttribute (panel, ATT_PANEL_PARENT, &parent);
GetActiveTabPage (parent, PANEL_TAB, &index);
switch (index) {
    case 0:
        // Code for the first tab page
        break;
    case 1:
        // Code for the second tab page
        break;
    .....   add extra pages code
Solution C: use callbackData parameter for the buttons
This solution requires code in two different program sections
* When loading the panel with the tab control
int    pnlH;
GetPanelHandleFromTabPage (panel, PANEL_TAB, 0, &pnlH);
SetCtrlAttribute (pnlH, PAGE1_BUTTON, ATTR_CALLBACK_DATA, (void *)1);
GetPanelHandleFromTabPage (panel, PANEL_TAB, 1, &pnlH);
SetCtrlAttribute (pnlH, PAGE2_BUTTON, ATTR_CALLBACK_DATA, (void *)2);
.... and so on
* In the button callback
switch ((int)callbackData) {
    case 1:
        break;
    case 2:
        break;
Message Edited by Roberto Bozzolo on 05-22-2010 09:21 AM
(3,492 Views)
