LabWindows/CVI
Utilization of the "Generate Function Tree..." tool
I am using the tool "Generate Function Tree...".
I encounter troubles when I am using the tag /// HPAR p1/helpfile1, ... with my parameters.
There is an error that says "Parameter specification incorrect."
Did someone has already use this functionnality of CVI before?
Here is my code:
/// HFP Instr_help.txt
/// FP Mon Instrument
/// ; Sets the function help for the function following this tag to the content of helpfile
/// HFUN Init_help.txt
/// ; Specifies which parameter of a function is output. This tag applies only to the function immediately following the tag.
/// OUT 2,3,4,5
/// ; Set the help for all parameters
/// HPAR LogicalName/logical_name_help.txt,hSignalGeneratorHandle/handle_he
lp.txt,iErrorOccurred/iErrorOccurred_help.txt,lErrorCode/lErrorCode_help.txt,sErrorMessages/sErrorMessage_help.txt
void __stdcall TCase_Init(char sLogicalName[], long *hSignalGeneratorHandle, int *iErrorOccurred, long *lErrorCode, char sErrorMessage[]);
Regards, Pascal.
(3,010 Views)
Pascal,
You need to use parameter indices instead of names. For example:
///HPAR 1/logical_name_help.txt, 2/handle_help.txt
Luis Gomes
NI
(3,010 Views)
