LabWindows/CVI
sscanf question
I keep getting errors (unknown specifier) on following code, using CVI7.0:
sscanf(temp_str, "%lg%*t", r64Result);
temp_str has numerical values. I don't know what the above format
specifier in sscanf means. Can anyone help. This is all over the driver
code that I inherited.
vishi
(3,888 Views)
I hope 'r64result' is a pointer to a double, since that is what is required here.
%lg means "scan a real number and put it in a double"
%*t doesn't mean anything, as far as I am aware, as 't' isn't a valid conversion specifier in ANSI C. Well, not the ANSI C I know anyway.
A long time ago, NI included an ANSI C reference manual with the CVI document set. Those were the days!
Martin.
Martin
Certified CVI Developer
(3,888 Views)
I don't have your final answer, but here's a little more breakdown on the format string in your statement.
%lg
g = floating point in e format (e.g. 5.4321E+03) or f format (e.g. 5432.1).
l = long (or double for a floating point number).
So %lg = double.
%*t
* = skip this field.
t = ??? unknown specifier (at least to me and CVI).
I couldn't find any documentation for a t format specifier. Since the * says to skip the field anyway, it seems safe to me to delete that term and to leave your format string "%lg".
Remember that sscanf (like other flavors of scanf) is looking for a pointer to the variable to be filled. Verify that the declaration for r64Result creates a pointer:
double *r64Result;
If the declaration is
double r64Result;
any other uses expect r64Resu
lt to hold a double, change the sscanf statement to
sscanf(temp_str, "%lg", &r64Result);
What tools were originally used to create your driver?
(3,888 Views)
Thanks guys. I knew about %lg, but have never seen "%*t". Oh well I
changed the code to use only "%lg" and it works.
vishi
> %lg
> 5432.1).
> So %lg = double.
> %*t
> pointer to the v
> double *r64Result;
> double r64Result;
> any other uses expect r64Result to hold a double, change the sscanf
> statement to
(3,888 Views)
