LabWindows/CVI
VISA not recognizing 3rd Party PCIe card
I have a 3rd party PCIe development board that I have been succesfull at reading registers from using the 3rd party software PCI Tree.  I am now trying to communicate with this device using NI-VISA.  I have run the VISA Driver Wizard and created an INI and INF file for the driver. Once I assign this driver to the device in the Device Manager, it shows up as an NI-VISA PXI Device.
The settings are correct when I look at the properties for the device:
When I open NI-MAX, this device does NOT show up. I have refreshed MAX several times, and it still does not see any devices.  I have also rebooted the computer and then re-opened MAX and refreshed, and still nothing.
My question is this:  does NI VISA handle PCIe devices?  What am I missing in the driver development wizard?  Why won't MAX find this device when it shows up in the Device Manager under NI-VISA PXI devices?
Thank you for any prompt help you can provide.
PS -- i have attached the INI and INF files
(3,788 Views)
Hi, C Gotsch.
Did you follow the Using the VISA Driver Development Wizard and NI-VISA DevZone?  Tell me step-by-step exactly what you did.
You can also see  all of your VISA devices in MAX by selecting Tools»NI-VISA»VISA Options, and then selecting Aliases under General Settings.  Does the PCIe development board populate in the List of Resources and Aliases?
Sara Lewandroski
Applications Engineer | National Instruments
(3,753 Views)
Thanks for your reply. I ended up doing a complete uninstall of all NI software on my PC and I started over and re-installed NI MAX -- and viola...everything worked fine.  So, something must have gotten messed up with the software.  Thanks,
Cathleen
(3,751 Views)
