LabWindows/CVI
Vector Xl xlLinsetSlave() interface issue
Hi, I am developing a flash tool to flash hex file for vector xl driver.I have written a
hardware configuration file for vector xl driver using interfaces provided by the vector. my configuration is fine as per example provided by the vector. but when i transmitting a data using xlLinSetSlave interface. i am always not getting a response from the hardware after sending a data.I am not understanding after sending a data using xlLinSetSlave interface , it is not always hitting to the hardware interrupt. as you can see in code that, the interface LINSendMasterReq used to send data from the application and inside interface, i am calling two interfaces xlLinSendRequest to set master request and linSetSlave to set slave for transmit and receive data.please have a look:
#include "Device.h"
#include "QString"
#include <qdebug>
XLstatus Device::LINSendMasterReq(unsigned char *data, int linID)
    XLstatus        xlStatus = XL_ERROR;
    char            tmp[100];
    // send the master request    xlStatus = xlLinSendRequest(m_xlPortHandle, m_xlChannelMask[MASTER], (unsigned char)linID, 0);
    // setup the only slave channel (LIN ID + 1)    xlStatus = linSetSlave(linID+1, data);
    return xlStatus;
XLstatus Device::linSetSlave(int linID, unsigned char *databyte)
    char            tmp[100];
    XLevent         xlEvent;
    unsigned char      data[8];
    for(int i=0;i<8;i++)
        data[i] = databyte[i];
    xlStatus = xlLinSetSlave(m_xlPortHandle, m_xlChannelMask[SLAVE], (unsigned char)0x3C, data, DEFAULT_LIN_DLC, XL_LIN_CHECKSUM_CLASSIC);
    Sleep(timeval);
    xlStatus = xlLinSendRequest(m_xlPortHandle,m_xlChannelMask[MASTER],(unsigned char)0x3D,0);
    return xlStatus;
(4,229 Views)
Accepted by chan2411
Maybe this is the wrong forum? I can't see any LabVIEW. Is it perhaps LabWindows/CVI?
(4,032 Views)
