LabWindows/CVI
Visual C++ Runetime Error from Build Distibutions Installation package
Hi everyone,
During January 2019 has our installation-package on our development eviroment stopped working.
We are running LabWindows CVI 2015SP1.
It's a Windows10 PC where I think an update has made the installation-package to stop working.
It works fine on other computers when trying to install, and I can also run the application directly from the Debug/Release build.
I can't however install the application on this computer.
See image below for error message when we try to install. You can also see the Microsoft Visual C++ packages installed.
Following procedure has been done to trying to solve it:
  • Installed latest .NET 4.7.2 package
  • Installed latest graphic card drivers to Intel HD 630 (by Windows update)
  • Removed/Reinstalled Microsoft Visual C++ packages from different versions
Anyone have any clue?
(3,060 Views)
Accepted by topic author viktor_morin
Hi Viktor,
I think this should help:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019YOnSAM&l=en-GB
Kind regards,
Ruta
(3,017 Views)
Thanks! It solved the problem!
(3,010 Views)
