Voice Over BLE
I want to record a voice comming from Bluetooth remote control Mic .
can someone help me ?
(3,536 Views)
Hello chayma
This question is very generic. It would be best if you gave more information like:
Which software do you want to use?
Which hardware are you planning on using?
How do you want to save this recording? Which format?
Have you already searched for some examples?
With this information we will have more insight and your chances of finding a solution will be higher.
(3,510 Views)
First, Thanks for the response Second, The goal for me is to do Voice test on remote controle: Check that the remote controle Mic detects the voice. It should be noted that this is a BLE technology. I want to use cvi for programming and i don't have yet the hardware solution or the software solution. I try with raspberry and i coudn't read data from the BLE remote control.
(3,504 Views)
Hello chayma
I found some information about the NI Bluetooth Toolkit. You can try calling the .dll in LabWindows/CVI. I'm not sure if your specific hardware will work with this toolkit.
NI Bluetooth Toolkit 15.0 - Windows 10/8/8.1/7/Server 2008 R2 64-bit
http://www.ni.com/download/ni-bluetooth-toolkit-15.0/5734/en/
(3,494 Views)
Thank you very much
I will try with it
(3,487 Views)
