02-10-2009 11:51 AM
Hi:
Is there a way to query the windows event log from CVI?
I don't see any of the Windows Event Logger functions available in the windows SDK provided with CVI 8.
These are the windows logger functions I'm referring to:
http://msdn.microsoft.com/en-us/library/aa385784(VS.85).aspx
I'm interested in capturing application errors from the event logs on stations running Teststand and CVI.
Dave
Solved! Go to Solution.
02-10-2009 02:57 PM
You can use the ReadEventLog function. it's documented in the Windows 2000 RC2 SDK distributed with CVI FDS 8.5.1. Not sure if it's documented in the SDK distributed with CVI 9.x
ReadEventLog
The ReadEventLog function reads a whole number of entries from the specified event log. The function can be used to read log entries in chronological or reverse chronological order.
BOOL ReadEventLog( HANDLE hEventLog, // handle to event log DWORD dwReadFlags, // how to read log DWORD dwRecordOffset, // offset of first record LPVOID lpBuffer, // buffer for read data DWORD nNumberOfBytesToRead, // bytes to read DWORD *pnBytesRead, // number of bytes read DWORD *pnMinNumberOfBytesNeeded // bytes required );
| Value | Meaning |
| EVENTLOG_SEEK_READ | The read operation proceeds from the record specified by the
dwRecordOffset parameter.
This flag cannot be used with EVENTLOG_SEQUENTIAL_READ. |
| EVENTLOG_SEQUENTIAL_READ | The read operation proceeds sequentially from the last call to
the ReadEventLog function using this handle.
This flag cannot be used with EVENTLOG_SEEK_READ. |
If the buffer is large enough, more than one record can be read at the specified seek position; you must specify one of the following flags to indicate the direction for successive read operations.
| Value | Meaning |
| EVENTLOG_FORWARDS_READ | The log is read in chronological order.
This flag cannot be used with EVENTLOG_BACKWARDS_READ. |
| EVENTLOG_BACKWARDS_READ | The log is read in reverse chronological order.
This flag cannot be used with EVENTLOG_FORWARDS_READ. |
The buffer will be filled with an EVENTLOGRECORD structure.
If the function succeeds, the return value is nonzero.
If the function fails, the return value is zero. To get extended error information, call GetLastError.
When this function returns successfully, the read position in the error log is adjusted by the number of records read. Only a whole number of event log records will be returned.
Note The configured filename for this source may also be the configured filename for other sources (several sources can exist as subkeys under a single logfile). Therefore, this function may return events that were logged by more than one source.
Windows NT/2000: Requires Windows NT 3.1 or later.
Windows
95/98: Unsupported.
Windows CE: Unsupported.
Header:
Declared in winbase.h; include windows.h.
Library: Use
advapi32.lib.
Unicode: Implemented as Unicode and ANSI versions on
Windows NT/2000.
Event Logging Overview, Event Logging Functions, ClearEventLog, CloseEventLog, EVENTLOGRECORD, OpenEventLog, ReportEvent
ReadEventLog
02-18-2009 02:17 PM
Thanks. After a bit more investigation and tweaking, I was able to get this function to work.
Cheers,
Dave
02-18-2009 02:47 PM
It's a lot of work to figure out the event logging stuff. I seem to remember creating a dll in Visual Studio with message resources in it to support the event logging. I used the resource compiler too i believe. I only used the event log on one project - in retrospect I'm not sure I can say it was worth all the overhead learning how the whole thing works. But, if you're doing commercial-grade Win32 / Win64 applications, it probably makes sense to know how - I think you have to use the event log to be an official "Windows" application.
Which makes me wonder if it's possible to create a true, Microsoft certified "Windows Application" using CVI? Can you meet all of the Microsoft Windows Application requirements from CVI?
Menchar
