LabWindows/CVI
We can’t do self test calibration on NI-PCI 6229 card. How we fix that problem?
Problem: We can’t do self test calibration on NI-PCI 6229 card.
After we install LabWindows 7.1 and NI-DAQmx then we put  NI-PCI 6229 card in to computer.  We can’t calibration NI-PCI 6229 card. Let see more details in Attachment
Thank you for suggestion
(3,367 Views)
Hello Fen,
Which version of the NI-DAQmx driver do you have installled on your machine? I would suggest downloading and installing the latest NI-DAQmx driver from our website.
If that doesn't work, please try the card in another PCI slot on your computer as there might be a resource conflict.
There is a discussion forum entry that address a similar issue. Please follow the link below for more information.
http://forums.ni.com/ni/board/message?board.id=250&message.id=18827
Also, I would like to know if this card was working ever or not?
Chetan K
Application Engineering
(3,332 Views)
Hello Chetan K
Thank you for your suggestion, I will try to fix this problem, and report result.
             Fen
(3,320 Views)
