LabWindows/CVI
What does the State_Information[] argument mean in the FIRFiltering() function?
I'm trying to write some digital filtering code but I have no experience with digital filters.  I think I need the FIRFiltering() function from the advanced analysis library.  This function provides arguments for the input data array, the set of filter coefficients, the output array, and also an array called the State_Information.  Where does this array come from and what is it used for?
(3,744 Views)
Accepted by LJM
Initial X Conditions contains the most recent inputs. The most recent prior input should be the last element in the array. The number of elements in this array should be one less than the number of elements in the FIR Coefficients array.
Mark E.
(3,696 Views)
Thanks Mark.  I was working on other things and it took a while for me to get back to this problem but now it makes sense.
(3,609 Views)
