LabWindows/CVI
What if the Result is -9 in MakeDir(arg)
MakeDir ("C:\\DATA");
assume the directory DATA exists.
Using the function MakeDir works great. It assumes that the directory does
not exist. If the directory does exist, the return is -9. There is a break
from the program. How do you get around this break and stay in the program
(3,816 Views)
"Lou Eichner" wrote:
>>MakeDir ("C:\\DATA");>assume the directory DATA exists.>>Using the function
MakeDir works great. It assumes that the directory does>not exist. If the
directory does exist, the return is -9. There is a break>from the program.
How do you get around this break and stay in the program>?
I assume this happens only in debugging mode.
This probably means you have "break on library errors" checked in the options-menu.
Uncheck it and the debugger won't break.
Good luck,
Steven Wellink
(3,815 Views)
Hello, Lui.
You can use something like this code:
int oldBreakState, result;
oldBreakState = SetBreakOnLibraryErrors (0); // disables break on
error
result = MakeDir ("C:\\DATA");
SetBreakOnLibraryErrors (oldBreakState); // restores the old
'break' state
if (result != 0)
// process errors
Yuri Gendelman
ygendel@birinc.com
Lou Eichner wrote in message
news:39cae397@newsgroups.ni.com...
(3,815 Views)
I know this is an old thread.  But I just want to reply in case someone is interested.
You may not want to create a new directory if it already exists.  Try this:
fileIsExisting = FileExists(buf, 0);  // buf is the directory you want to create
if (!fileIsExisting)
   MakeDir (buf);
Smiley Happy
-shylah
(3,606 Views)
