LabWindows/CVI
What is best CVI method to ping n packets to a device and monitor results?
What is the best method using CVI to ping a specified amount of packets to a device and monitor the response? Can CVI do this or do I need to monitor a terminal program to do it?
Mike
(3,438 Views)
Hello Spikeman,
In order to customize the data payload size of the ping command, or to specify the number of packets send to a device, you should use the ICMP functions provided in the Windows SDK.  You will then be able to set up a ping based on the specifications you need.
The following links should be helpful:
MSDN: Implementing Internet Pings Using ICMP.dll
MSDN: How to Ping an IP Address Using ICMP
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,398 Views)
