LabWindows/CVI
What is the confine to choose the minimal instalation?
what do you recommend me between this two modes:Typical/minimal instalation.
(3,271 Views)
Typical installation will usually be your best bet. It installs the most commonly used components that you as a developer would probably need. Minimal installation is usually only suggested if you have a very very limited amount of disk space or if you only want to install an extremely basic set of functionality. I would always recommend a developer to do a typical installation, unless they are short on disk space.
Jeremy L.
Jeremy L.
(3,271 Views)
thank you, sincerely.
Berenice Ramírez.
(3,271 Views)
Your welcome. Any other questions you have may be answered by posting to this discussion forum group, or if you would like one on one support, go to www.ni.com/support and you can either email us or call us! Good luck with your application!
Jeremy L.
P.S. - For future reference, the star rating goes as follows: (* = below expectations, ** = average, *** = above average, **** = excellent)
Jeremy L.
(3,271 Views)
hello, thanks again!!
I asked for the diference between LabWindows and Labview, talking about control instruments applications.
I worked with Labview a little bit to communicate with a instrument(fluke) via RS-232, but now I am working with labWindows(start learning).
Thanks sincerely.
(3,271 Views)
