LabWindows/CVI
When I load a new instance of a panel with a menu bar defined on it, the new menu bar and the old menu bar have the same ID.
I have a panel which I wish to reuse a bunch of times.  It has a menu bar on it.  When I seperately load, display, and operate more than one instance of this panel the menu bars are linked.  How should I make a panel with a menu in it which can be reused but the menus are all separated?
DS
(3,177 Views)
Well, actually the menus have the same IDs, but their functions receive panel handle as the last parameter so that you can differentiate various instances of the menus from this value.
(3,170 Views)
Thanks! I see the panel information is there but I do not know how to use it properly.
The code below makes only one item checked on a menu (you pick one item and it is checked and any others are cleared).
Do you have any suggestions how I might do that to only the menu that was picked and not the other menu on the other panel?
void CVICALLBACK select_deselect_exclusive (int menuBar, int menuItem, void *callbackData,int panel)
int is_checked;
  GetMenuBarAttribute (menuBar, menuItem, ATTR_CHECKED, &is_checked);
  if(!is_checked)
    int menu_id = 1;
    find_menu(menuBar,menuItem,&menu_id);
    while(menu_id !=0)
        SetMenuBarAttribute (menuBar, menu_id, ATTR_CHECKED, 0);
        GetMenuBarAttribute (menuBar, menu_id, ATTR_NEXT_ITEM_ID, &menu_id);
    SetMenuBarAttribute (menuBar, menuItem, ATTR_CHECKED, 1);
(3,162 Views)
ok i figured this out.
thanks for your help!
to make multiple instances of the same menu work you need to NOT associate the menu in the *.uir file and load it explicitly when you load the panel.
you can load lots of menus this way and they do not check / uncheck each other with the previous code i had
  if ((graph_report = LoadPanelEx (report, "ui_graph.uir",GRAPHPANEL,__CVIUserHInst)) < 0) return -1;
  if ((graph_report_menu = LoadMenuBarEx (graph_report, "ui_graph.uir", GRAPH, __CVIUserHInst)) < 0) return -1;
  SetPanelMenuBar (graph_report, graph_report_menu);
(3,158 Views)
