LabWindows/CVI
excel query table
Hi everyone
I need help with Excel activeX
I have an Excel Template file that I need to import a text file to a specific sheet.
The Macro shown below works
With ActiveSheet.QueryTables.Add(Connection:= _
      "TEXT;I:\533 calibration data.txt" _
      , Destination:=Range("A1"))
      .Name = "K5533 calibration data"
      .FieldNames = True
      .RowNumbers = False
      .FillAdjacentFormulas = False
      .PreserveFormatting = True
      .RefreshOnFileOpen = False
      .RefreshStyle = xlInsertDeleteCells
      .SavePassword = False
      .SaveData = True
      .AdjustColumnWidth = True
      .RefreshPeriod = 0
      .TextFilePromptOnRefresh = False
      .TextFilePlatform = xlWindows
      .TextFileStartRow = 1
      .TextFileParseType = xlDelimited
      .TextFileTextQualifier = xlTextQualifierDoubleQuote
      .TextFileConsecutiveDelimiter = False
      .TextFileTabDelimiter = True
      .TextFileSemicolonDelimiter = False
      .TextFileCommaDelimiter = False
      .TextFileSpaceDelimiter = False
      .TextFileColumnDataTypes = Array(1, 1, 1)
      .Refresh BackgroundQuery:=False
  End With
End Sub
This is done from the Excel Data Menu / Get External Data / Import Text File
I want to do the same thing using activeX
Here is what I have
ExcelObj_QueryTable retValue;
VARIANT varConnection;
ExcelObj_Range destination;
CA_VariantSetCString (&varConnection,"I:\\K5533 calibration data.txt");
error = Excel_QueryTablesAdd (ExcelWorksheetHandle, NULL, varConnection,
          destination, CA_DEFAULT_VAL, &retValue);
This is not working!!!!!
1) I dont know what to set destination to since it wont accept anything like "A1"
2) Do I need to add   Connection:=  to my destination definition
3) Is Handle to worksheet appropriate or to I need handle to workbook or application.
Sorry for long question but I am trying to provide as much info as possible.
Sure hope one of you can provide some suggestions
Thanks in advance
Mario
(3,584 Views)
Hi, Mario.
I notice that your macro begins with the line ActiveSheet.QueryTables.Add, which indicates that the handle needed in Excel_QueryTablesAdd () is the worksheet handle. (You can access the active worksheet handle with Excel_ActiveWorksheet().)
Determining the destination argument in Excel_QueryTablesAdd() is a bit more complicated, however. The specifics of that argument are provided by Microsoft, and they can be found as follows in MS Excel 2003:
1. Run Excel
2. Select Tools>>Macro>>Visual Basic Editor
3. Once the editor opens, select Help>>Microsoft Visual Basic Help
4. When the table of contents appears on the right side of the screen, select Microsoft Excel Visual Basic Reference>>Methods>>A>>Add Method
5. Select
Add method as it applies to the QueryTables object.
For further help with Microsoft's functions, I recommend checking out www.msdn.com.
Regarding your question about "Connection:=", I'm a little unclear about where you're considering adding that line. Can you elaborate on that a little more?
Good luck.
Sarah K.
Search PME
(3,560 Views)
Another answer to this was posted in another thread.
Sarah K.
Search PME
(3,546 Views)
