LabWindows/CVI
Where is DAQmxGetCIInputState???????
I've searched the DAQmx porting problem regarding GPCTR_Watch of DAQ. I found one of NI member said there is DAQmxGetCIInputState function monitoring the state of the counter in link below;
http://forums.ni.com/ni/board/message?board.id=180&view=by_date_ascending&message.id=29757#M29757
As you know there is no DAQmxGetCIInputState function even in DAQmx 8.9 full version library. I've searched NI-DAQmx function help file but it has not that one.
I need to monitor the input state or value of counter, but how can I do it?
I'm converting DAQ to DAQmx..from Parkoz.com
(3,773 Views)
Accepted by topic author anarkie
Are you trying to monitor the state of the counter? If so I think the function you are looking for is:
DAQmxGetCIOutputState
Jervin Justin
NI TestStand Product Manager
(3,766 Views)
