Robin,
Thank you for the quick response. I checked the help files as you recommended but the methods that are available from the CVI 7.0 ActiveX Server are not documented there. Help and or examples on functions such as CVI_FakeKeyStrokes that are exported from the CVI 7.0 Server are not available. A "FP" may be created to call the methods of the CVI 7.0 ActiveX Server by using the generate ActiveX controller wizard.
I have not been able to find good documentation on all the methods contained in the server or examples of usage.
Tom
